Sneak peak to what you guys are up against for the new 3dmark06 challenge
Unfortunately, 06' does not scale quad SLI on the SM2 correctly. Only uses 50% of each core. But the SM3 uses 75% of each GPU. I only scored 2k higher with quad SLI over a single GX2 in 06'. Vantage however scales correctly and it's a huge difference. Also, I had better results in 06' disabling hyper threading and using higher clock. 4.6ghz with HT and 4.8ghz no HT got the same CPU score, but increases SM2 and SM3 quite a bit with the higher clockspeed.
