longtalker
Hi everybody,
I have a very poor WiFi reception at my present location, and in order for Windows (XP) to stay connected to the WLAN, I have to use my laptop in awkward positions!
I already set the WLAN card's parameters available from Hardware Management that I thought might increase its reception sensitivity (Power Management, Roaming Aggressiveness, Throughput Enhancement, Transmit Power) to their maximum performance value, but even so, the difference between staying connected and getting disconnected is so small that if I move the laptop literally a few centimetres from its "preferred" spot, the connection is lost. I would therefore need a small extra boost in my network card's sensitivity - does anyone know how I might achieve this?
Many thanks in advance for any replies!
(I should add that I cannot in any way influence the positioning or any other settings relating to the router that supports this WLAN, so any tweaks would have to be performed locally, on my own WLAN card)
