Need Help with choosing Video Card !!!
BakerT
hi i have nvidia geforce 8500GT (1GB) video card but it sux i want to buy a new 1 (CHEAP) that i can play games like bad company 2 highest quality at around 40 fps and above (at reslution : 1650 1050) so please help me choose :D Thank You !
Processor:Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz (2 CPUs), 2.0GHz
Memory: 2048MB RAM
Hard Drive: 80 GB
Video Card: NVIDIA GeForce 8500 GT (PCIe x16)
Monitor: Plug and Play Monitor (LCD) (recommended res : 1650 1050)
Motherboard: Intel
Memory: 2048MB RAM
Hard Drive: 80 GB
Motherboard: Intel
Power Supply : Baord-X P4-450W
OK in that case get this card when it comes back in stock-
http://www.newegg.com/Product/Product.aspx?Item=N82E16814141108&Tpk=biostar 9600gt
You need a card with a single 6 pin power connector. I would need to know what exact model motherboard you have, but I seriously doubt it has a 2.0 PCI express x16 slot. It's probably a 1.0, so it won't put out the power requires for a no power plug 9800gt that I linked too in my first post. It needs help for the 6 pin power plug, so that 9600gt will be a huge upgrade from what you have and still work on your setup.
A 9400gt isn't much stronger than an 8500gt. A little stronger, closer to an 8600gt in performance.
cant i get a gts 250 or any other good card bcuz my screen is 1650 1050 and it needs really stong video card (forget about cheap)??? or should i get a new motherboard ?? and thnx for help :D
You power supply isn't strong enough for a gts250, it would probably blow and take your motherboard out with it. But if you can upgrade your PSU to a decent name brand 500+ watt PSU, than yeah you could get a gts250.
That being said, I've owned that exact biostar 9600gt, it's a decently strong card and would be enough for 1680x1050. I played COD WAW at 1920x1080 with it at 40-70 FPS.
Your CPU is actually more of a bottleneck than a 9600gt.
Yes just looking at it you can't tell. A 1.0 only runs at 1/2 the bandwidth as a 2.0 slot. And also, a 1.0 slot can only supply 50w of power to any given card, a 2.0 can supply 75w. See that 9800gt is meant for a 2.0 slot, it runs at about 60w I believe, so a 1.0 slot cannot handle it. BUT, each 6 pin connector can supply up to 75w of power also(in addition to the 50/75 from the x16 slot), so thats why I said you can run a card on a 1.0 slot as long as it has a 6 pin connector.
