memory
I am looking into building a new Core i7 system. I have decided to go with the LGA1366 socket instead of the 1156 socket just so it will last longer and costs about the same as a 1156 build. I have most of the parts picked out, I just need you guys to see if anything should be changed. I will be using the machine for gaming and multitasking. I would like to keep it under $1500, the cheaper the better but don't want to lose performance.
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Thought about getting the 930 since it is only 9 bucks more.
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
I would like to have one with the ROG OC tool but most of them are too expensive.
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820145222
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150487
Thought about getting a GTX480 but don't like what I have read about them using more power and more heat. I went with XFX because of the warranty.
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
I am kind of reluctant to get this because I am using the same drive right now and it may be causing me problems, not to sure.
What about a cpu cooler? Would the stock cooler be good enough? I plan on overclocking but nothing extreme. Which one would you suggest?
I am going to use the PSU and dvd drive from my current build. The PSU is a Corsair 850HX.
Anything that can be changed to lower the cost without losing performance or can I get better performance without raising the costs?
