Need help - 2DDR RAM upgrade
punkmartyr
I want to upgrade my ram and see if it helps some with a program I'm having problems with. My computer:
http://computers.toptenreviews.com/netbooks/lenovo/lenovo-8215e1u-details-6031.htm
RAM Technology: DDR2 SDRAM
Installed RAM: 512 MB
Max Supported RAM: 4 GB
Supported RAM speeds: 533 MHz
I need to know what RAM to buy.
This one looks compatible?
http://shop.lenovo.com/SEUILibrary/...23E104135B445F3A1A8CE1F31&&hide_menu_area=yes
But I can't find any 4 GB probably because this computer is a few years old.
I found this but theres no indication this 4 GB would fit in my computer:
http://cgi.ebay.com/NEW-Lenovo-4GB-...tem&pt=LH_DefaultDomain_0&hash=item5887ad2d8a
You have 2 slots with a 4gb. max of DDR2 533.
You could just get DDR2 667 chea...iption=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
Are you sure any of those on that page will work because I can go ahead and order.
I have very very low skill in the hardware part of computers. I have replaced rams and drives maybe a couple times my whole life. Most of it is plug and go these days thankfully. I'm a little better than the average person on software; I can make a computer bogged down by garbage as fast as the day it was purchased.
Thanks so much for the help I really appreciate it.
No reason why the memory would not back clock to 533. DDR2 667 probably has SPD/JEDEC setting back to 400. But there is a small chance that the board bios wont cooperate.
Is there a simple way to check
1. If my system is 32 bit or 64 bit (its prob 32)
2. How much of the 4 gb ram it will recognize (3 or 3. something from what i'm reading)
