I guess this is the correct subforum to post this in. I bought a Verizon air card and plugged in into my laptop. When it was almost installed, the screen turned black and gave me the following message:
"Windows could not start because of the following file is missing or corrupt:
systems32\Drivers\Nfts.sys
You can attempt to repair this file by starting windows setup using original cd rom.
Select 'r' at the 1st screen to start repair."
Whe I select 'r' it takes back to the same error message. What is the problem and what should I do? Thanks
