noisy graphics card fan
glenman
Hi ppl,
I just had a ATI Radeon 1 Gig card fitted to my ShuttleX today. The fan on it hums as bad as the fan on the old card, the bearings on that fan had gone. Long shot I know but anything I can do except throw the desktop through the window? :(:)
What card is it? You gotta tell us so we know how to fix it. Alot of powerful fans these days make a sound
AeQ - Sorry I'm late replying, I've been on holiday...It's a 'PowerColor' HD3650
... boy you are really behind on times huh :D over 2 generations to be exact. but anyway I remember my old 3870 agp made a LOT of noise. the 3xxx series just make a lot of noise. ur gonna have to deal with it unless u want to buy an aftermarket cooler and install that.
I can hear my hard drive over my 3870 fan, so not true that they all made alot of noise.
Clean out the heatsink and fan. Take the HSF off the card and take the fan off too. clean the thermal paste off the bottom of the heatsink using kitchen roll, or better yet, a lint free cloth of coffee filters. With the fan off the heatsink now, use a vacuum cleaner to get the worst of the dust out of the heatsink (don't do it with the heatsink on the card), then run it under some water. Use a hairdryer to dry it, as that will also blow off any dust rather than leave it there.
With the fan, use the vacuum cleaner on the underside, holding the fan still. You can let it spin, but it can (low chance of) damage the fan if it spins too fast.
Put it all back together and see how it goes. If it is still too loud, you are probably right that the bearings are gone. If that is the case, you have 3 options:
1. Put up with the noise
2. Take the fan off, and if there is a plastic cover over the heatsink, take that off too, and put a fan on there with cable ties or elastic bands
3. Get an after market HSF. I've got the Arctic Cooling Accelero S1 with 2 80mm fans on my 3870 and it is ~20 degrees cooler than the stock cooler was (stock was getting mid 70s, this doesn't go about 53) and was fairly cheap too. It comes with memory heatsinks and keeps them cool enough to touch (I know, bad practice, but goes to show how cool they are)
thats strange. I remember my 3870 being super loud. louder than my 4890 thats for sure.
depends on the brand because different brands use different HSF's. All cards will be the same unless they are tweaked (which the manufacturer will say), but will have different cooling sollutions, which is why you can't generalise with it
fair enough. that is true
