The (theoretical) gaming rig
fastdude
My gaming build :D ( It's just in theory A.T.M. just checking with you guys whether it all works out O.K. :)
CPU http://www.esaveronline.com/product/AMD+ATHLON+II+X4+630+2.8GHZ £73.25
Motherboard http://www.ewlink.co.uk/asus-m4a785td-v-evo---am3-socket---785g-chipset---atx-7229-p.asp - £63.40
RAM http://www.eferret.co.uk/product_info.php?products_id=43341 £84.80 + VAT (17.5% VAT rate, hence - £99.17
GPU http://www.saverstore.com/product/2...GB-DDR3--GPU-Clock-650MHz--Mem-16GHz--DirectX £52.32
PSU http://www.esaveronline.com/product...X+Power+Supply+Unit+{49}+24+Pins+{49}+Big+Fan £32.72
Cooling http://www.cclonline.com/product-info.asp?product_id=36082&tid=frooct £6.15
Case/cooling http://www.maplin.co.uk/Module.aspx?ModuleNo=221073 £49.99
TOTAL: £431 (approx.)
This is just the base unit, please alert me to any compatability issues/better things i could get for the same price (OR LESS!) Basically, alert me if there's anything cheaper on the market :D
Oh and I forgot! HDD - http://www.novatech.co.uk/novatech/...SATA500GBto1TB/WesternDigital/WD5000AAKS.html - £36.99
and............. CD/DVD drive - http://cgi.ebay.co.uk/LG-Writer-22x..._Storage_CD_DVD_Drives_ET&hash=item35a742704c - £19.49
Sorry it was so long! :D
only acouple things i would change if u have the extra cash
dont get value ram cuz it sucks
get a 5770 if u have the extra cash its only about 100 usd
I am not trying to be mean (I swear) but if you are going to build a gaming computer with that GPU (5450) just get a game consol like X-box. It will cost less and play better. That is not much of a card, I would consider the 5770 minimum. You can even look for used cards like the GT250 or something.
I'm not exactly in the know about GPU's, but it claims to have DirectX11 Support? SUrely that is good? I know it's not got mny stream processors but 1GB of DDR3 graphics memory can't be that bad, right>? thks :D
