How does this gaming pc look?
What power supply will you be running with those?
Black edition cpu's come with heatsinks.
Its more cost effective to get this processor and just overclock it though, 400mhz is not a big deal:
http://www.komplett.ie/Komplett/pro...II_X4_945__3_GHz_-/HDX945WFGMBOX/default.aspx
Or, if your willing to spend 20 more, get a phenom II X6:
http://www.komplett.ie/Komplett/pro...X6_1055T__2_8_GHz_-/HDT55FBGRBOX/default.aspx
This memory is quite a bit cheaper:
http://www.komplett.ie/Komplett/pro...GB__2_x_2_GB_-/BL2KIT25664BN1608/default.aspx
I'd recommend using money saved on memory towards a 790FX board over a 790X:
http://www.komplett.ie/Komplett/pro...therboard_ATX_-/GA-MA790FXT-UD5P/default.aspx
What PSU will you be using? Using a 5830, I'd recommend at least 500w-650w, probably 650w if you can afford it. Make sure you choose a good brand too.
If you get the AMD Black Edition, be sure to get a heatsink because I don't think it comes with one.
yes it does come with one but if you plan on doing any overclocking then you'll almost definitely need to get a new one. that is a great cpu but you could always go with the 955 and just oc.
the hd 5830 is also very good. it has really proven itself to be good for the money.
what is your overall budget and what do you plan on doing with this build (games and settings)? are these the only things you need or are you also going to buy things like the case, hard drives, or psu?
EDIT: nevermind on the hdd and case, but what about the psu?
Actually the heatsink and fan are included with the Black Editions. bomberboysk beat me to it!
According to the description that is an FX board. In total agreement about an FX board, however.
If you want to save some money you could go either with a a 955 or even a 945. Will you be overclocking?
@bomberboysk: curious; how is the quality of the DDR3 Ballistix? The reason I ask is because with their DDR1 and DDR2 Ballistix offerings they had serious issues with tons of RMAs. I speak from personal experience when I had six sticks of DDR1 fail. Don't get me wrong. I have used Crucial memory in upgrades and systems but I am gun shy of the Ballistix line.
Your thoughts/experience?
Sorry, I was just going off this
http://www.tomshardware.com/forum/251125-28-difference-processor-black-edition
If one plans to eventually overclock would Black Edition be worth it to get?
Also, you recommend getting the X6, but aren't most games still trying to catch up with utilizing 4 cores?
@bomberboysk
I just opened my case and on the psu it has to values 550w and 650w and the brand is active pfc,so I'm not really sure tbh as i built this computer 4 years ago
As for the cpu I think I will stick with the b.e. for the sake of the money and the x6 is new and i can renember some problems with the quad cores when they came out with amd so i think i will stay clear of that one
Ah I didnt see that memory and I shall get that mobo instead
@joh06937
Well I dont have a budget so to say as I set out with a small budget and sorta went way over it so anything under 700 is what I'm trying for.And I honestly dont play high end games to much just bf2 project reality.But I do play newer games at 1980x1800 some times so my old gt9600 512 cant really handle that so well
@Slacker7
I've never explored the road of over clocking as I've never seen the need to but I would like the option open to if I ever want to
And sorry for the wall of text I'm a really bad writer :/
A good 500W is plenty, the only reason to suggest a 650W is if the user plans on running crossfire in the future.
The problems with the ballistix lied alot in the single sided DDR2, crucials DDR3 has been some of the best value for money memory out there. OCZ has quite alot more issues with memory than crucial, only problems i have seen with crucial other than the standard failure rates from any manufacturer were their original high voltage ddr3 offerings(which, alot of manufacturers had some issues with that as well, but then again about 3 companies make the majority of IC's used by memory manufacturers).
As far as the board, the GA-790XTA-UD4 is a 790X based board, as far as i can tell Komplett.ie pasted the wrong description onto it from the GA-790FXTA-UD5.
For €20 more you get two more cores, which helps with multitasking, as well as the fact that games continue to use more and more multithreading to take advantage of multi core processors. At one point i remember people saying how a quad wasnt worth it for gaming, and then people realized games such as gta IV essentially neded a quad to run well.
And yes, the "original" 5000+(65nm) and 6400+(90nm) black editions did not come with a heatsinks, i actually helped a buddy of mine build his first rig with a 400W psu, 5000+ black edition, xigmatek S-963, 2gb of memory, and a cheap foxconn boards. All black edition processors since then however have come with heatsinks.
b.e. are definitely worth it in my opinion. unlocked multipliers really help with overclocking :D
Only when running cheaper boards/memory, on air anyhow. Unlocked multis really start to shine once you get to sub ambient though.
@bomberboysk
@joh06937
@Slacker7
There were no "problems with quad cores" when they came out, the Phenom II X6 in the simpliest of terms is just a Phenom II X4 with two more cores(a few other features were added, such as turbo boost). Even if you do plan on exploring overclocking in the future...i would suggest going with the 945 or 965, the 965 is one of the biggest wastes of money IMHO, especially considering the 955 has an unlocked multiplier as well.
Also, "active PFC" just means active power factor correction, we need to know the brand. If it is unbranded, you will want to look into getting yourself a new power supply as cheap power supplies are very prone to failure and can damage your components.
@bomberboysk
If I recall Amds first quad cores werent great but disregard what I say if I'm false as I dunno what I am talking about
Ok so I guess I will get the x6
Ah right sorry I thought that was the brand :X The brand of the psu is OCZ Technology
Thanks for all the help btw
@bomberboysk
Oh, now i know what you are talking about. AMD's first quads had a TLB error that could be partially be fixed by disabling the L3 cache, however it was a brand new platform when that happened, while the Phenom II X6's are based off of the existing Phenom II platform, and reviews are positive on it;)
Alright, OCZ is a good brand for power supplies, you should be fine;)
Memory speeds on the board are only what it "officially" supports, but in reality the memory can be "overclocked" to the rated 1600mhz speeds.
Sorry for the alte reply.
Can you give me a quick guide or send me in the direction of one?As I'm not sure the ones I found on google are talking about the same thing.
Thanks.
