cpu cooler
if you plan on overclocking i would highly suggest it. if not, then you might be able to get away with it. i would recommend getting the cpu, putting it in with the stock, and then checking the temps and decide then (unless of course you do overclock, in which case you'll most likely need a new one).
Id get an aftermarket cooler even if you dont plan on Overclocking,Theyre just better that the stock coolers and will keep your Cpu cooler. :)
Which one to get though depends on how much you want to spend on a cooler :)
Thermalright true 120 is a good choice since according to HARDOCP the performance difference is negligible between the venomous and the true but the price difference is like 10 bucks
-EVGA 012-P3-1470-AR GeForce GTX 470 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
-Sunbeam PSU-COM680-BK-US 680W ATX12V Modular Active PFC Power Supply
-Core i7-930
-ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
-G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model F3-12800CL9T-6GBNQ
-HITACHI Deskstar HD31000 IDK/7K (0S00163) 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
-Rosewill DESTROYER Black Gaming ATX Mid Tower Computer Case -
-LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04
i want to spend around $1000 and my current build is $1160 and I do not plan to overclock so do i still need a cpu cooler?
i would just try out the stock and looks at the temps when it is at 100% and decide then. you never know, you could get away fine with just the stock one.
one another note, nice build :good:
you might want to try the board Gigabyte GA-UD3R-x58A the board is of $209 and is an awesome board with usb 3.0 and sata II
