need links to amd motherboard QUICK!!
kdfresh09
hello. so i am in need of a motherboard. i would like to be able to order it from newegg, and within 24 hours from today 6-9-10. it needs to be an am3, im only using one card a gtx260, maybe sata 6 and usb 3, but can always order add in cards later. if 2 pci e 16 slots try and make them dual 16. ideally i want something that is rock solid for overclocking an athlon II x 4 630, 1 pci e 16 slot, something that has been solid by facts, through testing or something. i really need your help on this on cause ive never had a costum built amd machine. my budget i suppose would be around $150, but lower if possible. i also need a good cpu cooler, so some links on that would be great as well. the budget for that will be up to $50. thanks all for your help
Edit: I think I miss understood the budget.
Mobo -
ASUS M4N98TD EVO for SLi
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131636&cm_re=980a-_-13-131-636-_-Product
GIGABYTE GA-870A-UD3 for single card
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128443&cm_re=amd_870-_-13-128-443-_-Product
CPU cooler
Scythe SCMG-2100 Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185142
If your overall budget is $300 for CPU + Mobo + heatsink, I would recommend you get Phenom IIx4 955 ($160) + Gigabyte/ Asus AMD 870 mobo ($100) + Scythe SCMG-2100 ($35)
Motherboards
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128435
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128441
CPU cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835887016
