How fast is a 7 mbps Connection?
BurningSkyline
My ISP is Qwest, And I'm using their 7mbps package. And to be honest, It doesn't seem that fast. I mean, I Have to wait to watch youtube videos, and A 20 Minute 2000k (HD) stream takes quite a while to buffer. I mean, Is this normal for having a 7 mbps package?
I went to speedtest net and took the test 5 times. Here are the averages:
Upload: 0.59
Ping: 156
That's really bad, ring up and complain. 7mbps is 7168kbps, which equals 896KB/s (amlost one megabyte a second.)
1024kbps = 128KB/s (bits and bytes, theres a difference)
What I don't understand, is that When I'm downloading a song, or something it averages at 156kbps... and I can upload at about 80... I wonder why speed test isn't getting those numbers.
Depends on the source you are downloading from. Some servers are slower than others, try a download from a FTP and see if it maxes out ur connection.
Until recently I used 2mbs, It was good I thought.
But obviously, if your company are selling you a rated speed of which you are not recieving (try speedtest.net) then you'd need to telephone them.
Slow!!!!!!!!!
Upload: 0.59
Ping: 156
Well Mine 54.0Mbps so urs is pretty slow
Call qwest and tell them you are not getting anywhere close to your rated speed, you are getting less than 25% of what they are selling you for rated speed. 150KB/s(Kilobytes) equates to about 1.2Mb/s(Megabits/second) which is about what speedtest is showing.
