hd 3650 upgrade?
darbz1987
hi im looking for a more powerful card then my currunt hd 3650 512mb card but my psu is 500w but only has 18amps on the 12v line :-( so i need a better card but not much juicyier power draw wise then my 3650 any ideas? thanks i heard the 4670 isnt power hungry?
you will love that card i have it and it plays so many new games with a dual core
but it cant play crysis or battlefield bad company 2
hey what you mean you cant play them games? i can play them both on my pc with 3650 with decent settings no lags
Go check out my post
http://www.computerforum.com/177543-amazing-setup-low-end-gaming.html
Went to a buddy of mine that works at Computer Deli and he advised that setup...
Mobo - Heatsink for bio's , Crossfire , Up to 16gb of ram
CPU - AMD Athlon II x2 250 True Dual Core
Video - ATI Sapphire HD Radeon HD 5670 1gb (Crossfire supported) (GDDR3)
Total around 280$ - Not including Ram, Liquid Cooling "optional", Case (Make sure has high air flow, cooler you keep your pc the better it runs), HD, ODD, PSU
No reason to go and spend 1200$ on a system imo and it be outdated within 3-5yrs when you could go and spend 500$ on a system and do the same thing enless your wanting to pull 100fps on high graphics settings in Massive Populated Multiplayer games.
But thats my opinon
But thats my opinon
Hey Dukelewis78 where are you from??
