Well I guess you could open it up and install some LED's. not sure how you'll power them though, either through USB or another power adapter I guess.
Yeah, I am looking into installing leds throughout to put lights through the speakers.
Does anyone know if I could swap out the Latitude e4300 backlit keyboard with this? I would assume not...
You can use any keyboard you wont it's doesn't matter if it's a Dell or not.
Its a laptop. And I would like to replace the internal keyboard. If I get an external, I would get a mac keyboard.
Ah I see, Well to install your on LEDs you would need to know how to do some basic wiring, soldering, and where to solder them to get power. If you can confirm that the e4300 keyboard would work then I would do that. Seems like to much of a hassle for just some pretty lights. Might just wont to get a little light that plugs into the USB if you wont to see at night.
Those looks like they almost could fit. Is there a way I could just whack off the think under the space bar and have it still work? Or would that render it useless?
You mean the part of the keyboard that is supposed to connect to a motherboard that is nothing like the one you have in your laptop? Yeah, go ahead and whack it off.
