How Do I Power More Fans
well the fans came with adapters that go from molex to the fan plug ins, but I don't think I have any way to get power from the psu to the molex.
nevermind I got it, I didn't realize the ones that came with the fans were males. Just plug the fan in and go off the daisy chain that is plugged right into the power supply, nothing else to it? how fast will the fan run and all that?
idk ill see how it is if its to loud ill solder them up to the built in fan speed controller or use the bios if i can
did I just get thread robbed :( haha, edit: that or maybe you posted in the wrong thread?
anyway, aside from quality of the knobs and such, do I run any damage or other risks by going with some cheapo ebay fan controller knob(s)?
lol ops
If you have a decent motherboard you can get some adapters that allow you to plug 2 fans into 1 connector on the mobo. as long as they don't have high current draw or are server fans you should be fine.
