CD Writing Speed
mreccentric
At what speed should burn my CD?
Is Writing speed related to data to be burnt?
Is it different to Diff CDs/DVD's ? How to Determine it?
The slower you burn the better you'll be. The faster you burn, you might get errors.
Personally I avoid CDs now, I don't even use DVD's.
I got a 500 gig USB hard drive which I store data on.
How many CD's could that hold? About 600?
How much does 600 cd's cost?
If you want music get mp3 players and usb memory sticks.
How much space does 600 cds take up?
How long will it take you to find the CD you want in that pile? - about an hour!!
I hope you get the message, you are wasting time energy space and money.
If they cost 10p each they cost more than my hard drive!!
How reliable are CD's? not very!!
How flexible and reusable are they? Not very.
Still a time and place for DVD's, Cd's and dual layers. Yes i do use them. Mostly for family pictures, etc. its called portability.
also make backups on HD's.
They are not obsolete yet......
thanks... but why so?
whats the reason?
In my regard, there's no flexible storage device...
but some times, i need to burn DVDs...
When you burn at a faster speed there are more chances of burning missing files. When it burns at a slower speed there is less of a chance. I mean it won't happen all the time, but you are better off burning at a slower speed.
Portability? I'm pretty sure that an external hard drive is more portable than the equivalent data burned to CDs/DVDs. Optical media is good if you want to give someone some data and you don't want it back, and they're convenient to boot from, but that's pretty much it. Optical media is definitely on the way out.
I pretty much gave up on CDs and DVD's a while back.
They present a lot of problems in reliability, you can record something and find a few years later the data is gone.
As I said my 500gig drive could hold as much as 700 if my figures are right.
OK it would be mainly DVDs these days and what are they about 5 gig each, that's still a stack of 100.
I have burned some stuff to DVD occasionally but i never tend to use them again as i am to lazy to sort through then and find them, what you wrote on it 2 years ago might make little sense now. On a hard drive it's easy to list and play a sample or whatever.
Then there is the hassle of putting them in cases, not scratching them etc..
Also what is the point of having stuff on CD when it is usually a click away on the web? on youtube for example?
To tell the truth I hardly ever use my USB drive either, so not only is optical media dead, magnetic media is dying too!!
High speed internet kills them both off.
I mean things like the Ipad or whatever will be more of the future way to go.
What is the point of millions of people having their own copies of stuff?
Even if it is personal stuff you could upload it to a server.
I remember a professor at uni predicting that we would all eventually move to
getting out data from a central server, I though he was mad but I think he is right now.
As for portability I have 4 gig of storage on my mobile phone!
Twice as much as on my first PC!!
And that 4 gig cost £6.30!!
Also I have tonnes of data, video etc that I have saved but I never look at it!! You think it is worth saving at the time but you never look at it again.
Stuff becomes dated so fast and there is so much new media coming out you don't have the time, it's all on youtube for you anyway, and so easy to find.
Certainly my days of burning discs are pretty much over.
Easiest way is to use a usb stick, very portable, cheap holds loads of data.
They present a lot of problems in reliability, you can record something and find a few years later the data is gone..
Data Gone! where did u store the disc...
i'm pretty much afraid now; cos i have my back-up DVD's, which are as old as 3 years;after hearing you, i'm afraid what would happen... :eek:
The surface of the disk can deteriorate (th metal not the plastic).
You should check them, I checked some old ones and they had problem.
Also they might not work in a different player.
I had a lot of problems, there are just too many negatives with Cds.
Never had a problem with hard drives bar one which was about 8 years old and had not been used for 3 years.
And if you have a 100 cds to check it will take forever!!
CDs just suck!! :cool:
Also I smoke and smoke can get on the CD lens, it can get dirty anyway, it's just all hassle.
