Need a good AMD cooler
okami 11x
Hi,
As the title states, I'm looking for a cooler for my AMD computer.
The socket type is AM3.
I've looked on Newegg and only found a couple small sized fans.
I did find this one (and I've used this one for my last build socket LGA 775)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
but I've seen many bad reviews for using with AMD processors.
So I figured I'd appeal to as many people as I can to see what people think and suggest since this is my first AMD build.
@Bacon:
I would rather not spend over 50 bux if I can help it. That said, though, I want to make sure my processor will last as long as possible so even 100 bux in the short term is better than having to replace my processor in a year.
@FuryRosewood:
Thanks for the suggestion. I'll look into that one more...I didn't read the reviews on it yet.
@Aastii:
Thanks for the links but neither of the Rifle coolers have AM3 socket listed as compatible (although they look like they could cool my system very well)
@Aastii:
They list AM2, which IIRC has the exact same mounting system as AM3.
I've used the Arctic Cooling Freezer 64 cooler on my last 2 builds-overclocked both of them and never seen temp over 44 during normal usage-Running current build at 3.6 when needed and is real quiet.
@VoyagerFan99:
That looks beast but I'm not a fan of the blue leds...I don't really need my computer glowing lol
@Craneop1985:
I think I'll be going with that one. I've liked Artic Cooling in the past and I think I'll stay with them.
Thanks for all the help everyone!
