pci express
Do you know the model number of the motherboard? Or what brand and model number of computer it is if it is store bought?
Yes, that does have a pci-express video slot. FYI, your motherboard is the MS-7366. Look between the pci express and pci slots.
brilliant thankyou the card im lookin at says PCIExpress 2.0 x16 so everythink should be ok?
It will 'probably work' however this motherboard only supports gen 1.0 PCIe which is ocassionaly incompatiable with PCIe 2. The minimum 'will work' is PCIe 1.1a. I would check with MSI prior to purchasing.
Secondly, JOsh, you need to ensure you have a suitable PSU before you upgrade your graphics card.
