Enermax Pandora 185
Wireframe
Hello,
I have a computer case enermax pandora 185. I was just wondering if i can remove the side panel on the other side?
Because i remove the two screws and then i was trying to remove the side panel but i couldn't.
The front side panel is easily removable.
Does any of you have a similiar case? Where can i get users manual for the case?
It will be a little stiff and the little recess on the panel doesn't help really. Keep trying, it will slide off.
If the panel is riveted in place then it won't slide off.
Are you sure? Because i have the motherboard on that side, and if it isn't removable i can damage the motherboard.
And the main problem is that i can't see where exactly is the motherboard attached with the case.
The motherboard is mounted on a separate tray. If you have removed the screws for that panel then it should slide out.
I've had a look at the Enermax Pandora 185 on Newegg and the picture shows the panel riveted to the frame. So your's must be a revision if you have screws for both side panels.
