Cannibal Ox
Hello! I'm planning to build this desktop in the near future, and I'd appreciate some help picking parts. The main things I'm looking for in my desktop are: longevity, performance, price and a hint of aesthetics, in that order.
Longevity is probably the most important aspect I need in my computer. I'm looking for longevity in both the durability of the parts, and steady performance over time.
For the performance aspect, I'm not looking to build a hardcore gaming computer by any means, but I would like it to be at least able to run games like Battlefield BC2 and Call of Duty MW2 on medium to slightly higher settings. I more often play games that are more leisurely, such as Black and White 2 and Portal, and I would like to have games such as these run smoothly.
Pricing should fall somewhere between $300-$450 dollars, and the lower end of $300 is preferable, however, the balancing between price and performance is difficult so if switching out a few parts for a slightly more expensive, more durable+better performing part is available, that is the more preferable option, and my final price is around $400 dollars anyway from the parts I listed. But if there are cheaper, better options (better being equivalent +cheaper or just better+cheaper), please suggest them!
The aesthetics aspect is just more of my personal vanity seeping in, and I know I could probably chop off $40-50 dollars with a simpler case, but ah what the hell, I want something pretty.
So here's what I got so far (sorry about the above reading, I just wanted to be thorough)
Total Price: ~$420 with shipping
As you'll see if you click on the links, I'm down with the rebates so if any of you find anything with a rebate that's a pretty good offer, feel free to post it! I am looking to cut the price down if an equivalent and cheaper or better and cheaper tradeoff exists. Thank you all who post in advance, and thank you readers for reading.
- Mobo ($70): ASUS M4A77TD Motherboard - AMD 770, Socket AM3, ATX, Audio, PCI Express 2.0, Gigabit LAN, USB 2.0, SATA, RAID
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5367037&sku=A455-2883
CPU ($70): AMD Athlon II X2 250 Dual Core Processor ADX2500CGQBOX - 3.00GHz, Socket AM3, 2MB Cache, 2000MHz (4000 MT/s)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695458&sku=A79-0250
Video Card ($65): EVGA 01G-P3-1235-LR GeForce GT 240 Video Card - 1024MB DDR3, PCI-Express 2.0, DVI, HDMI, VGA
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5648548&sku=E145-0248
Power Supply ($30): Corsair CX400W Power Supply - 400-Watt, 120mm Fan, SATA-Ready, 80Plus,ATX
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4236686&sku=C13-2507
Hard Drive ($40):Western Digital WD5000AAKS Caviar Blue Hard Drive - 500GB, 7200rpm, 16MB, SATA-300, OEM
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2795126&sku=TSD-500AAKS
RAM ($48): Kingston 2GB 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) Desktop Memory Model KVR1066D3N7/2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134751
Case ($80): NZXT Guardian 921 Blk ATX Mid Tower Case
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4146013&sku=A406-1102
