You think these fans will work with my case?
The second one will work for the exhaust and hard drive cage, as for the deltas I'm not sure, depending on where the fans are(facing towards or away from the front) you might be able to, but those are LOUD they are rated for 64db, that would be like a vacuum cleaner on 24/7
Yea, I read that. But I need some air circulation and 200cfm will do it. haha
Do you have a suitable alternative for the delta then? Noise is SEMI important but I don't really care too much.
Don't buy from newegg, if you are getting delta's get them from gary:
http://www.sidewindercomputers.com
I have some QFR1212GHE-F00's and they are quite loud, not quite vacuum cleaner, but loud nonetheless. The FFB1212EHE's are not as loud, and move quite good air. If you are looking for high cfm fans that are loud but not crazy loud, the 3000rpm ultra kaze's are quite good for the price.
My only concern now is fitment. Mine don't have screws in them, they snap into place.
