Hi!
I have just bought some new hardware:
Intel Core™ i7 Quad Processor i7-930, Quad Core, 2.8Ghz, Socket 1366, 8MB, 130W, Boxed w/fan
Gigabyte GA-X58A-UD3R, X58, Socket-1366, DDR3, ATX, USB3.0, SATA 6Gb/s, 2xPCI-Ex(2.0)x16, Revision 2.0
CORSAIR TX 750W ATX12V 2.2 / EPS12V
But I have come up with a problem:
I simply can’t find out if my PSU, motherboard and CPU is compatible and therefore my build have come to a tragic stop.
CPUpower connector (motherboard) - http://img168.imageshack.us/img168/918/40575850.jpg
Corsair PSU CPUpower cable - http://www.corsair.com/_images/products/hx_eps-atx12v_8-4_pin.jpg - 4-pin.jpg
Full motherboard - http://img36.imageshack.us/img36/5614/39748157.jpg
Q1: My motherboard says it needs ATX_12V_2X (8-pin) to power the CPU, what is that?
Q2: Are ATX12V / EPS12V PSUs supported/ compatible with ATX_12V_2X motherboards?
Q3: Will my PSU work just fine on this ATX_12V_2X motherboard (Gigabyte GA-X58A-UD3R) or do I have to look for another PSU with an ATX12V 8-pin CPUpower cable?
Q4: EPS12V = 2x4-pin ATX12V CPUpower?
I’m asking for your expertise.
Thanks in advance
/M9A2
Thanks in advance
/M9A2
