agent_redfield
I have a large amount of viruses on my laptop and need help getting them off. Here is all the information I have.
1: I am not an admin on the computer so I can't install things
2: the computer says task manager is infected and won't open it when I use ctrl alt delete
3: apparently rundll32.exe is infected according to a security warning dialog that popped up
4: there are a bunch of anti virus programs that all of a sudden appeared on the laptop and look very suspicious and will not remove things unless I enter my information to purchase them
5: one is called antimalware doctor
6: another is antivir solution
7:stclogin.exe is said to be infected
8: internet explorer will not let me go to any websites and says: "visiting this website may harm your computer" on any thing I type in
9:spybot is under all programs (I dont know if that program is bad but it sounds suspicious)
10: when I exit out of the antivirus programs they immediately open up again
Please help me fix these viruses. If you need any more information I'll try to get it. thank you
