cmd does not work I click on the cmd He came second out
netanel305
cmd did not work for me
Hello!
When I click run the cmd is in and out right I tried to complete guides but did not help
I have windows 7 ult
I think what he or she might be asking is why typing cmd in the Search programs and files bar doesn't cause cmd.exe to run like it does with Windows XP. If this is the question, it is because OP needs to enable the run command in Windows 7.
Start > right click > choose Properties > Start Menu tab > Customize > scroll down and check Run command > OK.
Next time the OP clicks Start, a new run bar will appear above and to the right of the Search programs and files bar. Enter cmd in this bar and he or she is golden.
