My wifes desktop, which is running XP Home, has a problem. It is an AMD XP3500 IIRC, running on a Biostar MOBO. It has two HDDs, the one with XP is a 160 GB SATA. The other drive is a 40 Gig with a Linux distro loaded on it which she never uses.
The problem started about two weeks ago. The computer boots OK, but it displays a message on bootup about wanting to run chkdsk. If you let it run it gets part way then hangs up. If you cancel chkdsk on bootup it boots and then after about 5 minutes the computer freezes. Every thing works fine up to that point. It freezes even if you don't do anything but let the computer just set after booting. I tried doing a system restore but it won't restore. I tried defragging but that tells me to run chkdsk first.
I have managed to backup a few smaller files in the short time before it freezes but she has tons of photos and stuff and the computer locks up before I can even get close to backing that up.
I think there is a registry problem or problem with the HDD. If I boot into the Linux OS every thing works fine which makes me think it isn't a memory problem or the MOBO.
FINALLY, MY QUESTION:
Can I unplug the drives and install a new SATA HDD and reload XP, with that drive set to boot, then plug the old drive in as a secondary and access it from my new drive in order to rescue data and files?
