Raid 0 Western Digital Green Caviar 500GB x2 or One 1tb drive?
Drumstick
I've been wondering if it's worth getting another WD Green Caviar drive (500GB) and setting up RAID 0 with my other WD 500GB drive or just buying a 1TB drive.
I've been told that having a 1tb will have the same performance as two 500GB drives.
I'm from Australia if pricing helps with suggestions.
CPU: AMD Phenom x4 II 925 @ 2.80ghz
Memory: Corsair Dominator 2GB @ 1880 mhz(If I'm correct) Single Channel - Soon to be dual channel.
Most boards support hardware RAID now but if not you can still software RAID them with the OS.
That said, I wouldn't suggest RAIDing WD Greens. You could get a 1TB WD Black for less than the cost of 2 500GB greens.
what motherboard do you have? Does it support software raid?
Gigabyte GA890-GPA-UD3H, it does support software RAID controller, it's controller Gigabyte Raid Controller I think.
In the instruction manual, it says I have to press ctrl+f to access the raid setup on the post memory test or something but it comes appears to fast
Yeah, I was also considering this :)
You have to switch it to RAID mode in the BIOS first (see manual page 85). Once that's done, you should see the 'Press <Ctrl-G> to enter RAID Setup Utility ...' just after POST.
FYI, no board supports hardware raid. Its technically firmware raid, which is somewhat of a combination of hardware and software raid. Its a decent cheap way to implement raid on a motherboard.
It depends on which JMBXXX is used, if its the 36x series then you're right it's not a hardware RAID engine but generally speaking software RAID is associated with a RAID set up by your OS not some external setup program.
