Im looking to buy a new graphics card in a few days, but im sort of confused about a few things. I have about 80 dollars to spend on a new graphics card. My computer model is eMachines ET1831-05. Looking preferably for an 512mb graphics card at least,. Mine came with a integrated graphics card and its really holding me back with the mmogames I play, I get really low FPS. Not looking to run brand new games Just MMO's which generally have standard or low graphic requirements(128mb graphics). My power supply seems to be 250 watts.
1.Can I use PCI Express 2.0 cards? I heard I can from a friend(Backward compatible?) but would that reduce my performance enough to not get a 2.0?
2.I read a few places that you need to have a certain power watt to run cards? Does mine meet the requirements for a decent graphics card.
3.What graphics card would you recommend for my computer for around $90 or less.
Computer Specs:
CPU-Z Report
Computer Specs:
Intel Celeron Processor 450 (2.20 GHz, 512 KB Cache, 800 MHz FSB)
500 GB SATA hard drive
3 GB of installed RAM (1 x 2048MB & 1 x 1024MB)
NVIDIA GeForce 7050 integrated graphics
SuperMulti optical drive with the following write speeds: 16x DVD±R, 8x DVD±R DL, 6x DVD-RW, 8x DVD+RW, 5x DVD-RAM, 48x CD-R, 32x CD-RW
Fast Ethernet networking (10/100)
Multi-in-One memory card reader compatible with CompactFlash (Type I and II), CF+ Microdrive, Secure Digital (SD) Card, miniSD Card, MultiMediaCard (MMC), MMCmobile, MMCmicro, Reduced-Size MultiMediaCard (RS-MMC), xD-Picture Card, Memory Stick, Memory Stick PRO, Memory Stick Duo, Memory Stick PRO Duo, Memory Stick Micro
Ports: six USB 2.0 (two front, four rear), two PS/2, one VGA, six audio ports (7.1 channel audio support)
Expansion slots: two PCI (available), one PCI-Express x1 (available), one PCI-Express x16 (available)
Expansion bays: two 3.5-inch HDD (1 available), two 5.25-inch ODD (1 available)
High-definition headphone jack and microphone jack
Windows 7 Home Premium makes it easy to create a home network and share all of your favorite photos, videos, and music. And you can watch shows for free when and where you want with Internet TV on Windows Media Center. Get the best entertainment experience with Windows 7 Home Premium.
Get more features with Windows Anytime Upgrade. It's the best way to add features to Windows 7, takes as few as ten minutes, requires no software or downloads, and you'll keep your existing programs, files, and settings. Windows will walk you through the simple upgrade process.
Pre-loaded software includes Microsoft Works SE 9.0 for word processing and spreadsheet work. Enjoy a 60-day trial version of Microsoft Office Home and Student 2007.
Dimensions: 14.2 x 7.1 x 16.2 inches (HxWxD)
Weight: 18 pounds
CPU-Z Report
