Help with video specs...
Being integrated I'd assume it would be 32mb/64mb/128mb
You can probably set it to share system memory as well.
How would I do that? Is that where it just takes some from the RAM and makes the card that is a 64mb into a 128mb or however much it is?
Basically, you can set it in the BIOS to allocate an amount of RAM for the GPU to use only, and becomes unavailable for system use.
