Weird, Recurring Problem With Graphics
Happy_LandFiLL
In the past I've had problems with games where I would start up the program and my screen would do a few, really quick flashes of a completely black screen and generally my system would lock up for a bit. After a while the game would continue to load up and then all the textures and everything are just....weird.
In the past I remember updating my drivers and maybe doing something else and it would generally fix the issue. However, this problem has reared its ugly head again and even with updated drivers I'm not sure how to rid my computer of this problem.
Mind you, this only happens with games. Any other video, program, software does totally fine.
I have included some pics of the World of Warcraft login screen below, to give you an idea of what in the world is going on. I'm no computer guru but I'm 98% sure this is a graphical problem.
Thanks in advance for the help!
Slapping myself for forgetting to include that.
PSU: Thermaltake Toughpower 750W
http://www.thermaltakeusa.com/Product.aspx?S=1207&ID=1502
Here's my DxDiag:
System Information
Time of this report: 8/11/2010, 07:51:04
Machine name: HAPPY-CF9CBF47B
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100216-1514)
Language: English (Regional Setting: English)
System Manufacturer: americanfuture
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5600+, MMX, 3DNow (2 CPUs), ~2.8GHz
Memory: 2046MB RAM
Page File: 844MB used, 3094MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_C8293842&REV_A2
Display Memory: 640.0 MB
Current Mode: 1680 x 1050 (16 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0012.5896 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/9/2010 18:38:00, 6343040 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/9/2010 18:38:00, 10604128 bytes
Device Identifier: {D7B71E3E-42D3-11CF-FA4C-25E803C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0xC8293842
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Sennheiser USB Headset
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\Vid_1395&Pid_3556&Rev_0004&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: usbaudio.sys
Driver Version: 5.01.2600.5512 (English)
WHQL Logo'd: Yes
Date and Size: 4/13/2008 14:45:12, 60032 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0x444
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
USB Audio Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC041
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Saitek Eclipse II Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x06A3, 0x8021
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x036C
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 14:45:37, 59520 bytes
| Driver: usbd.sys, 2/28/2006 08:00:00, 4736 bytes
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/13/2008 14:39:48, 14592 bytes
| Driver: kbdclass.sys, 4/13/2008 14:39:47, 24576 bytes
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/13/2008 20:13:20, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 4/13/2008 14:39:47, 23040 bytes
| Driver: mouhid.sys, 2/28/2006 08:00:00, 12160 bytes
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 65.9 GB
Total Space: 305.2 GB
File System: NTFS
Model: WDC WD3200AAJS-00L7A0
Drive: D:
Model: HL-DT-ST DVD-RAM GSA-H55N
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 14:40:46, 62976 bytes
System Devices
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_81E41043&REV_03\4&FC29FAF&0&0070
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 14:40:29, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 14:40:30, 96512 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 2/28/2006 08:00:00, 3328 bytes
Name: Gigabyte GN-WP01GS PCI WLAN Card(Turbo)
Device ID: PCI\VEN_1814&DEV_0301&SUBSYS_E9341458&REV_00\4&2BE4B97F&0&3830
Driver: C:\WINDOWS\system32\DRIVERS\rt61.sys, 1.00.0003.0000 (English), 10/27/2005 16:06:30, 356096 bytes
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&2A
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&29
Device ID: PCI\VEN_10DE&DEV_037F&SUBSYS_82391043&REV_A2\3&2411E6FE&0&28
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_0377&SUBSYS_00000000&REV_A2\3&2411E6FE&0&78
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 14:36:44, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_0375&SUBSYS_00000000&REV_A2\3&2411E6FE&0&70
Name: Other PCI Bridge Device
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82391043&REV_A2\3&2411E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0373&SUBSYS_82391043&REV_A2\3&2411E6FE&0&40
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_10DE&DEV_0371&SUBSYS_81F61043&REV_A2\3&2411E6FE&0&31
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 4/13/2008 12:36:05, 144384 bytes
Device ID: PCI\VEN_10DE&DEV_0370&SUBSYS_00000000&REV_A2\3&2411E6FE&0&30
Device ID: PCI\VEN_10DE&DEV_036E&SUBSYS_82391043&REV_A1\3&2411E6FE&0&20
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036D&SUBSYS_82391043&REV_A2\3&2411E6FE&0&11
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 14:45:35, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 14:45:36, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 20:12:08, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 14:45:37, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 20:11:54, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_036C&SUBSYS_82391043&REV_A1\3&2411E6FE&0&10
Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 14:45:35, 17152 bytes
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_036A&SUBSYS_82391043&REV_A2\3&2411E6FE&0&0A
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0369&SUBSYS_82391043&REV_A1\3&2411E6FE&0&00
Driver: n/a
Name: SM Bus Controller
Device ID: PCI\VEN_10DE&DEV_0368&SUBSYS_82391043&REV_A2\3&2411E6FE&0&09
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0360&SUBSYS_00000000&REV_A2\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 14:36:41, 37248 bytes
Name: NVIDIA GeForce 8800 GTS
Device ID: PCI\VEN_10DE&DEV_0193&SUBSYS_C8293842&REV_A2\4&5E1D6BE&0&0078
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 139776 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/9/2010 18:38:00, 232968 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 10604128 bytes
Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 7/9/2010 18:38:00, 61440 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 6343040 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 1388544 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 10260480 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 4595712 bytes
Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 2506344 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 2914408 bytes
Driver: C:\WINDOWS\system32\nvdata.bin, 7/9/2010 18:38:00, 2195030 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 7/9/2010 18:38:00, 7959 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0012.5896 (English), 7/9/2010 18:38:00, 13549568 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 7/9/2010 18:38:00, 25836 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0062.0040 (English), 7/9/2010 18:38:00, 604776 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.09.0022.0107 (English), 7/9/2010 18:38:00, 236136 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.09.0022.0107 (English), 7/9/2010 18:38:00, 236136 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_808B1043&REV_00\4&2BE4B97F&0&5830
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 14:46:18, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 14:46:18, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 14:51:25, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 14:51:25, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 09:46:40, 6400 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5933
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5933
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.4503
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5933
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5933
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5933
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0051
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5933
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.4503
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5933
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5933
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.4503
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5933
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5933
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5933
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.4503
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5933
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.4503
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.4503
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.2600.5512
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5933
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5933
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5933
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5933
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.4503
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5933
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5933
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5933
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5933
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5933
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5933
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5933
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5933
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5933
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5933
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5933
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5933
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5933
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5933
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5933
Audio Capture Sources:
Sennheiser USB Headset,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming Capture Devices:
USB Audio Device,0x00200000,3,2,,5.03.2600.5512
WDM Streaming Rendering Devices:
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
Sennheiser USB Headset,0x00200000,1,0,quartz.dll,6.05.2600.5933
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5933
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5933
DirectSound: Sennheiser USB Headset,0x00200000,1,0,quartz.dll,6.05.2600.5933
WDM Streaming System Devices:
USB Audio Device,0x00200000,5,2,,5.03.2600.5512
Windows up to date?
Update DirectX
Update video drivers?
Game updates?
What is the graphics card temp during gaming?
Dust in your computer?
That PSU should be sufficient. It could be many things.
