I found a great Gaming computer deal tell me if its worth it
Japjeev
Hmm what do you mean no power supply? i wont get a power supply?
sorry I was mistaken:
Power Supply: 450 Watt
however, it will be a POS. If you are wanting to get that video card, you will have to invest in another, better quality one
i am sorry but what is POS? also i just want to get average graphic card like 9800GT. So it cant run graphic cards? with 450 Watts?
Piece of <Insert profanity begining with the letter S here>
It isn't just the wattage, it is the quality of the unit. A good 400W power supply will power it easily. For instance:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822011
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
the diablotek won't power anything substantial at all as it will end up blowing. The corsair however will comfortably power the system you are looking at. Generally, though it isn't always the case because low quality parts can be used, look at the +12V rail(s). The higher the amps on there the better, you want most of your power on there.
So going back to the diablotek and corsair unit, look at the specs:
Diablotek:
+3.3V@26A, +5V@35A, +12V1@12A, [email protected], [email protected], [email protected]
Corsair:
+3.3V@20A, +5V@20A, +12V@30A, [email protected], [email protected]
The corsair has more than double the output on the +12V rail than the diablotek. It isn't just about power output though, problems can be caused by cheap units. I posted about this yesterday in this thread:
http://www.computerforum.com/180919-please-look-my-components-offer-upgrade-advice.html
uhh what if i dont buy the graphic card for a while. will i be ok? and if i do buy a graphic card and buy the corsaiir PSU i said will i be good?
If you don't get the graphics card for a while it should be fine yes, but I would get a better unit before putting a video card in there
=EDIT=
Can I point out too that for the same price you can get an XFX 9800gt:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150489
which will perform the exact same, however, comes with a lifetime warranty
hmm i will stick to radeon sinced it has 1gb memory. but what do u mean better unit?
better PSU (power supply unit)
and video memory means nothing unless you are at very high resolution. Look at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139046
for instance. 9500gt with 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125288
9800gt 512mb
even though the 9800gt has only half the video memory of the 9500gt, it still wipes the floor with it in every situation
9800gt 512mb
well i have a 1080p monitor so for that i probably do need 1GB. but yea you did make a good point. i might get 9800GT
which radeon were you referring to? Remember that you will need the power to drive all of those pixels, you don't JUST need video memory to work at high resolutions
hmm looks good also i have another question is 4 Gb ram more then enbough for casual gaming?
yes, 4GB is plenty for any game out now and that will be coming out for a while. Most only "need" 2GB (so say the specs).
Look through the system requirements of the games you want to play and you will see what I mean, or, I happen to have 4 game boxes next to me, the specs on them for memory:
GoW: 1GB
BF:BC2: 2GB
WoW:1GB XP, 2GB Vista/7
CoD:MW2: 512mb XP, 1GB Vista/7
