vonbismarck
Hello all. Hopefully someone will be able to help me. Late last night/early this morning I tried to upgrade my computer from windows 2000 to xp pro. I found an upgrade disk, popped it in and checked to see if there were any compatibility problems. It said that one piece of software might not work but that was it. With that I went and installed it. The installation went fine but, once all done, it will not boot into windows. At the point where the xp logo would appear, the screen goes black and then the computer resets. If I I try safe mode, it goes until to gets to loading AGP440.sys (I think that is what it says) before freezing for a few seconds and then rebooting. Is there any way I can fix this?
Also, to make things potentially slightly more difficult, I accidentally, while barely awake, did a regular install of xp. It didn't overwrite my old install as I can see all my files that I had even if I can't access them (because the software isn't installed on this install) and, when the computer boots, it asks if I want to boot to Windows XP Professional or Windows XP Professional (the second one is the one that constantly reboots itself).
Hopefully someone can help and thank you all ahead of time for trying.
