Memory
Architecture
DDR SDRAM
Memory connectors
two
Memory capacities
128-, 256-, or 512-MB
Minimum memory
128 MB shared DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
2 GB
Memory type
PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
Thanks Cromewell, I read that over too and now I'm confussed. I did go to the Dell site and found this for upgrade. . http://accessories.us.dell.com/sna/...s&l=en&s=dhs&cs=19&sku=A0740429&mfgpid=190929
So if this ram is a 400mhz/pc3200 and they say it is for the Dell Dimension2400 then the Kingston KVR 400/1 GB 184 pin DDR SDRAM/PC 3200 that I have should work, right?
Thanks
