HELP!! I used my USB to Install XP..now I can't boot XP without the USB Stick
jayland28
Hi everyone...I reinstalled XP on a PC (IBM Thinkpad R-40) with no CD-ROM. So I booted from a USP Stick which had the XP installation on it.
Well everything worked fine, I got XP loaded on the Laptop. BUT my problem is NOW I have to have to BOOT from the USB to get WINDOWS XP to load.
This is how I get XP to load.
1) I put the USB stick in
2) Boot from USB.. cause the C:Drive says Data Error
3) When I boot from the USB Stick.. the menu it loads is below...
[Boot Loader]
Timeout=30
Default=multi(0)disk(0)rdisk(1)partition(1)\WINDOWS
[Operating Systems]
C:\$WIN_NT$.~BT\BOOTSECT.DAT = "1st, text mode setup (Boot from flash again after finished)"
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="2nd, GUI mode setup, continue setup + 1st start of Windows" /fastdetect
C:\ = "---> DEBUG, in case of HAL.DLL or NTOSKRNL.EXE not found errors <---"
multi(0)disk(0)rdisk(1)partition(2)\WINDOWS="Debug boot rDisk 1 partition 2" /fastdetect
multi(0)disk(0)rdisk(1)partition(3)\WINDOWS="Debug boot rDisk 1 partition 3" /fastdetect
multi(0)disk(0)rdisk(1)partition(4)\WINDOWS="Debug boot rDisk 1 partition 4" /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Debug boot rDisk 2 partition 1" /fastdetect
multi(0)disk(0)rdisk(2)partition(2)\WINDOWS="Debug boot rDisk 2 partition 2" /fastdetect
multi(0)disk(0)rdisk(2)partition(3)\WINDOWS="Debug boot rDisk 2 partition 3" /fastdetect
multi(0)disk(0)rdisk(2)partition(4)\WINDOWS="Debug boot rDisk 2 partition 4" /fastdetect
I select the second to get windows to load...
"multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="2nd, GUI mode setup, continue setup + 1st start of Windows" /fastdetect"
HELP how can I get my XP to load on it own with out the USB Stick.
So does it matter what USB stick you put in? Seems a little odd in the first place but if you were to put in just any thumbdrive would it work? Or does it specifically need the one it was installed with?
Hi
Thye boot files are on the USB... not sure why they loaded on there. So when I want to log on to XP.. I have to boot from the USB and either select the OS Installation file or BOOT to OS..
You may need to reinstall again to load the boot files onto the C: drive. Be mindful of where the install is going.
