I have been looking into building my 2nd computer for a while and I've finally gotten the money to do so
. My previous computer I built was 2 1/2 years ago and my god I didn't realize so much changed x.x so I've been for researching for 2 days straight getting myself up to snuff but I'm still not confident if what I came up with is the best and ultimately the most bang for my buck. I have duel monitors and probably will get a 3rd monitor and G-card mid next year. The primary uses I use my computer is for 3d modeling,photoshop, and video editing and need things to move and operate as smoothly and fast as possible because I'm always have multiple editing programs open at the same time on duel monitors. I'm hoping to spend only $700 max but the lower the better every dollar matters. I think everything should be compatible, I would like a more experienced opinion on the build I came up with.
Also all I need is a CPU,GPU,Mobo, and Ram everything else I have.
Processor:
Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core Desktop Processor BX80605I5760
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067)
Motherboard:
GIGABYTE GA-P55-USB3 LGA 1156 Intel P55 USB 3.0 ATX Intel Motherboard (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128425)
Memory:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL (http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277)
Hard Drive:
3.0 TB (2x 1TB HD's, 150Gb Rapter Driver (Os Installed), 2x 500 GB HD) (Taken from my previous rig)
Video Card:
GIGABYTE GV-N460OC-1GI GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333)
Power Supply:
ThermalTake Toughpower 700 Watt (Taken from my previous rig)
Monitor:
Duel Widescreen 19" Dell (Taken from my previous rig)
Sound Card:
X-Fi XtremeGamer Fatal1ty Pro Series (Taken from my previous rig)
Operating System:
Windows 7 Pro
Computer Case:
Cosmos 1000 (http://www.newegg.com/Product/Produ...9138&cm_re=cosmos_1000-_-11-119-138-_-Product)
Total So Far: $643.97
Processor:
Motherboard:
Memory:
Hard Drive:
Video Card:
Power Supply:
Monitor:
Sound Card:
Operating System:
Windows 7 Pro
Computer Case:
