heej aastii,
thnx for ur explenation. I basicly just want a game pc with GTX460 GPU in it so I think a quad-core is better for my use. I am dont some searching for quads and found a i5-760 is this a good price/qualety for what I want or is there a better option
Yes, the 760 is a pretty decent CPU, only downside is locked multiplier, but that can be lived without as you get double the L3 cache of the K processors
That's a very good bang-for-buck intel quad. (just a higher clocked 750)
slightly Quicker than 1055T, too. (in games, at least)
It isn't surprising really, clock for the clock the Intel CPUs are faster, so in a game where the same number of cores are being used, 140MHz difference in clocks isn't enough to give the thuban the edge.
fasterdude, I know it dont really belongs in this post but I just want to ask it. I have now a CoolerMaster HAF 922, a GTX 460 1 GB, a i5-760. but I am a but stuck about what motherboard to take, like I know there are some options like AM3 and AM3+ but I dont really know what it means. I want is for games and if its possible for upgrading in the future. hope you(or someone else) can help me.
There are 2 main manufacturers of processor, AMD and Intel.
AMD's current socket is AM3. They have AM2 and AM2+, but they are being phased out, all of their current processors, your phenom II, Athlon II, Opteron and sempron processors are for socket AM3. AM3+ hasn't been released yet, but will be a crossover between AM3 and AM4, the same as AM2+ is a crossover between AM2 and AM3. AM3+ isn't out yet, but will suppor the bulldozer chips coming out next year
Intel has 2 sockets, LGA1156, and LGA 1366. The only major difference is that 1366 can support triple channel memory, where as 1156 can only support dual, same as AM3. The CPU you picked out, the 760, is socket 1156, so you will need a 1156 motherboard.
What is your budget for the board?
I'd recomend going for a board with SATA 6 for greater upgradability, however it adds quite a bit to the amount that you pay:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131634
you can go with one without which would be ~$100
