Okay this is the build I came up with. Any recommendations to make this cheaper or better?
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811129042
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136218
ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102873
AMD Phenom II X2 555 Black Edition Callisto 3.2GHz Socket AM3 80W Dual-Core Desktop Processor - C3 Revision HDZ555WFGMBOX + BIOSTAR TA785G3HD AM3 AMD 785G HDMI Micro ATX AMD Motherboard
http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.500523
OCZ Fatal1ty OCZ550FTY 550W ATX12V v2.2 / EPS12V SLI Ready 80 PLUS Certified Modular Active PFC Power Supply
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341022
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL8D-4GBRM
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231275
