computer case recommendation
jhooga
Well the case i have (CM Storm Scout) is a mid towerr and supports E-ATX motherboards. I'd go for a full tower if you were watercooling and such.
Midtower is fine.
It's a good case but doesn't have a painted interior, if you care about that. Personally, I like mine all black :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Anybody have one of these? or have any comments on them? thinking about getting one
I have the Cooler Master HAF 922, the little brother to the 932 full tower. I like the case very much. There isn't a whole lot of cable management, but there is enough to make me happy. As linkin said as well, the inside isn't painted but meh, it makes for a good project in the future :D
Edit: for the cable management, I was talking about the 922, not the 932. Not exactly sure on the CM features on that one.
I would stay away from the XCLIO Blackhawk. A friend of mine has that case and that side fan caused a lot of trouble with cpu cooling options.
922 is a nice case as well. Not bad and a lot smaller, only reason i was looking at 932 full size case was because i wanted to either put liquid cooling or the coolermaster v8 heatsink in it. Plus with my gpu its long i wanted more room. Do you think the 922 would fit it all nicely?? Im OC my cpu and gpu so the more cooling the better
that is a pretty sweet case, i ended up picking up a thermaltake blackwidow v9. got some monster fans, so far i love it, tons of room in it!
I need a ATX tower for my upcoming PC. I want to build a gaming pc. I think lots of overheated component need to be installed. Like GTX Video Card, XFX Mother Board and many more. So I need to find a good ATX tower for that. Do any body has any suitable suggetion for me?
well i just picked up teh themaltake v9 blackwidow and i love it, has lots of cooling in it, seems to keep all my components super cool, roomy not a lot of room for cable management without doing some modifications but i recommend it i love it a lot
