Intel Core i7: 930 vs 870 vs 860
Skitsofrenic
I used to think the ones with higher number was better but I don't know much about CPUs.. so here I am to ask the professionals!
I picked 930, 870, and 860 because those 3 are priced close to each other.
- Which one of those 3 comes out on top?
- If they are all priced exactly the same, which one would you take home?
- What are the Pros and Cons of each CPUs listed?
- Are those 3 cores used for different purposes or are they the same except for the speed?
he means that would be a "con" and not a "pro."
Haha I see.. Can anyone explain why 930 would result in a more expensive build than 860/870?
Also, tech savvy recommended that I go with 950 than 930. Would paying $50 more for a 950 be worth it? In what ways is the 950 better than 930?
950 isnt worth $50 more than a 930, only thing that is different is a slightly higher clockspeed. I'm assuming your looking at microcenter, as the 950 is about $50 more there than the 930($249 and $199 respectively).
The 930 would be more expensive than a 1156 based system, as 1366 motherboards are more expensive, and it costs more to buy three DIMMs of memory vs two dimms of memory.
Yep, I was looking at microcenter as they have sweet deals on CPUs right now.
So 860/870 uses the 1156 and 930 uses the 1366? Are 1156 and 1366 both Motherboards? If so, regardless of the price.. which one is better?
And about 930 requiring 3 memory doesn't bother me as I can just get a decent 3x 2Gbyte memory deal.
1366/ 1156 is the socket type
860/870 => LGA 1156 => H55/H57/P55 chipset. Mobo $80 - 180 (depends on what you need)
Support RAM dual channel, most ppl would get 2 x2GB RAM
930/ 950 => LGA 1366 => X58 chipset. Mobo $190 - 300 (depends on what you need).
RAM support triple channel. Most ppl get 3 x 2GB RAM
X58 platform is the better one. Are you going to SLi or Crossfire?
Nope, don't think I'll go sli/cross just yet. Maybe when I get some more cash to spend, I could go with an upgrade.
Even if I wasn't going sli/cross, would the 1366 build still be better with an extra ram?
Just comparing the 930, 870, and 860, which one of the 3 is a superior cpu?
I think that the 870 is a bit faster than the 930, but if you can afford triple channel memory (three dimms) then you should get a bit more speed with the 930, since it uses the X58/LGA1366 platform. Honestly, I think the difference is negligible. You can get the 870 or the 930, depending on which motherboard & RAM you want to get. A setup with the 870 should also turn out around $200 cheaper.
Just another note: the 930 should offer more upgradability, since you can buy hexa-cores for socket 1366. Still, I don't think it makes much of a difference since in a few years you should be able to buy one of Intel's next-generation CPUs with a new motherboard that's cheaper and just as fast as the 980x.
Awesome reply, thanks!
Yea as far as upgradability goes the 930 wins without a doubt. They are replacing the 1156 socket with 1155... Not sure why but as far as i know 1366 isnt going anywhere
No problem. :o If it were me, I'd probably go with the 870 for experimental reasons. Since it uses Socket LGA1156, I could put in one of the dual-core i3s for some fun overclocking. :good:
Eh, if you drop down to 1156 your number of PCIE lanes is cut in half, you drop from Triple Channel memory down to Dual Channel Memory, etc.
