kemperhills
I have a problem I can't find a solution to. I went to the Java website but they want $50 to solve the problem.
Here's the problem. I got a bug, in spite of two security programs and had to recover my computer with the recovery disc. Then Java wouldn't work. I deleted it from the Add/Delete. I can find no Java files on my computer using Search. It is not listed in Add/Delete. Windows Installer Cleanup utiltiy doesn't reconize any files.
Yet when I try to download Java from Java's site I received the following messages: First, after the download completed I received this message, "Java Setup: This software has already been installed on your computer. Would you like to reinstall it". I clicked "yes". Then I received this message, "Windows Installer: This action is valid only for products that are currently installed". I clicked "Ok". Then the first message appeared and when I clicked "yes" the second message appeared again. When I clicked "Ok" the messages disappeared but nothing has been installed. I am truely confused now. And help. Thanks.
