can i add more ram with this spec ?
lenson88
Operating System: Windows XP Home Edition SP3
System Manufacturer: MSI
System Model: MS-7252
BIOS: Default System BIOS
Processor: AMD Athlon(tm) 64 Processor 3200+, MMX, 3DNow, ~2.0GHz
Memory: 1520MB RAM
You're limited to 3GB of ram while using a 32-bit operating system. So yes, you can upgrade, and it should make a noticeable difference.
Just make sure you buy the right type of RAM, theres DDR, DDR2, and DDR3. My guess is that you are currently using DDR2. But make sure to double check, take your current stick out, and there should be a sticker on the side which has the type identified. DDR3 wont work in a DDR2 motherboard.
Thanks! i found already,it DDR2.
But, i should buy 1x1GB or 1x2GB ? it is same ?
What do you use your system for? If you are just a normal user that surfs, emails, and stuff then 1.5 gb of memory is sufficient. However, you may want to get more memory if you do any medium to heavy gaming.
I use it for Gaming , surfs , emails. So, Which should i buy ? 1x2GB or 2x1GB.
And Which Graphic Card suitable for my spec ?
