Ethan3.14159
Finally put my PC back in the good ol' CM 690 Pure. The Silverstone HTPC case was just a nightmare.
ill see your
C2D E6300 @ 2.6Ghz
Gigabyte GA-965P-DS3
2GB DDR2 667
1TB (1x500GB 2x250GB HDD)
BFG 8800GTS 320MB
and raise you a:
smilodon raid max case
amd athlon x4 635 propus
4 gb g.skill ripjaw rams
500 gb hard drive
9800gtx+ nividia geforce
650w psu
gigabyte 770A-UD3 mobo
man the monitor is way the hell up there
Heres mine now that it got cleaned and rebuilt,I took everything out gave it all a good clean.
I will get an inside shot tommorow![]()
sexy, very very nice
*drools*
Here's a little project I had a work during some free time. Basically we had three HP Pavilion N 5xxx laptops; two from one technician, one from my dad. After disassembling them all, I found the best parts among the rubble that still worked and rebuilt one single laptop. To top it off, I figured I'd customize it a bit. These laptops came out well before wifi was offered in most laptops sooo I found some spare antennas from an old Toshiba laptop and a Atheros mini-PCI card, wired everything up and viola! I'm actually using this laptop right now, running Wifi and everything.
Intel Penitum III 850MHz
256MB PC133 RAM (maxed out)
30GB HD(Mint and XP)
S3 Savage GPU with 8MB dedicated
15" 1024x768 LCD
DVD-ROM/CD-RW (considered throwing a DVD-RW in it, but it's kinda a waste)
Floppy drive
For such an old laptop (pre-XP days) it's quite capable still. As long as I avoid flash-based sites, this browses around as quick as any other computer. Plus it's got a really nice keyboard on it.
Now why can't HP make laptops like this anymore??? This thing is probably nearly 10 years old and running fine. I've had less than one-year-old HPs come into the shop completely dead!
I Like.Thanks heres that inside shot,Sorry for the bad quality :/
Hey Everyone. I finally finished my "Black Widow" build. I might do some more cosmetic work in the future but I am not entirely sure yet. Enjoy!![]()
