BurningSkyline
Or just an nvidia chipset to run SLI? and PhysX?
Short answer no. As long as you have PCI-E X16 slots you can run any card you wish. Having 2 Nvidia cards in SLI would require an nvidia chipset like you said OR you can has a driver hack to enable SLI.
If you have 2 cards, you could also use one for PhysX and one for main gpu processing without any hacks or anything.
So PhysX works fine without a Nvidia chipset?
People keep saying I can't get an AM3 board with Sata 3 and USB 3.0 and have an nvidia chipset. Honestly, It doesn't sound like a problem anymore.
Yes Physx works on AMD chipsets, you can have 1 nvidia card, or you can hvae an ATi card + nvidia card for dedicated physx
you know, actually i think the 470 and the physx card should work. pretty sure sli is the thing lacking that causes problems but you wouldn't be doing sli with that setup...
