BurningSkyline
I want to build a pretty decent pc with a lower budget.
How much does the cache matter?
I love the Athlon II x4 640. A novice can speed it up to 3.5GHz no prob and they run cool.
The L3 cache is nice on the Phenom II's, but you are paying more for less overall processing power.
Are you talking about comparing the processing power of a Phenom II Quad-Core to a Core i5 750 Quad-Core?
Wait a minute. For the price of the i5 760, you can get a six core Phenom, which will definitely be better at rendering.
The Athlon will do just fine, though.
Yep^
Though for everything else, the i5-7** will be much quicker. An i5-760 is just an i7-930 without hyperthreading.
Yep^
artificial benchmarks, yes, but you show me a real world application where you can notice a massive difference
Before recommending anything:
What will you be using the system for?
You said about video rendering, but how much will you realistically be doing?
what is your overall budget for this, or is it just for an idea of how much you would have to save/spend?
