Rubik's Hub
heiowge
I normally do mods on rubik's cubes, but on this occasion I have crossed into your territory!:D
Rubik's Hűb (spelt hub, pronounced to rhyme with "cube") is a fully functional USB 2.0 hub built inside a no longer (in any way at all) functional cube.
Have a look if you want at my youtube vid on it if you want...
http://www.youtube.com/watch?v=4_OVU3b2mWE
Thanks. It took a few days of tinkering to get right. Once you remove the core holding it together and most of the insides to fit the hub, it doesn't want to stay in a cube shape long enough for the glue holding the cubies together to set.
