JareeB Active Member Oct 8, 2010 #1 i new a new gpu idk heres that ones i have found in my price range 100-130 usd hd4870 i heard this card has a bad heatsink? hd 5670 is this even a good card? gts 250 idk if you got a really sweet deal for me pm me plz. or a better card for the money
Gooberman Active Member Oct 8, 2010 #2 don't get a gts 250 get the 450 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130572 from what i've heard the 5670 is around the 9800gt in performance Last edited: Oct 8, 2010
D daisymtc Active Member Oct 8, 2010 #3 You could also consider 5770 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161338&cm_re=5770-_-14-161-338-_-Product
JareeB Active Member Oct 11, 2010 #4 daisymtc said: You could also consider 5770 http://www.newegg.com/Product/Product.aspx?Item=N82E16814161338&cm_re=5770-_-14-161-338-_-Product Click to expand... i thought the 5770 isnt good for gaming
jevery Active Member Oct 11, 2010 #5 You can still get the GTX 460 1 GB for $178 if you buy tonight. Best price/performance at the moment. http://www.techbargains.com/news_displayItem.cfm/226660?r1=1
tech savvy Active Member Oct 11, 2010 #6 it would have to be between these two,HD5770 and gts450.IMO ill throw in the extra $$ and get the ZOTAC 460 768mb for $144.99 after MIR which beats both by a good margin,here.- http://www.xtremesystems.org/forums/showpost.php?p=4532422&postcount=39 5770- http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873 price $139.99 450- http://www.newegg.com/Product/Product.aspx?Item=N82E16814130572 price $129.99 460- http://www.newegg.com/Product/Product.aspx?Item=N82E16814500173 price $144.99(after MIR) edit-if your buying today/tonight go with what jevery said, i think the deal ends tomorrow. Last edited: Oct 11, 2010
