WoW Patch 4.0.1/cata Graphics?
Frost_Bite
Hey, i donno if it is that rare on here but i am a dedicated world of warcraft player and with the release of patch 4.0.1 and soon cata i am thinking i need a new graphics card,
Atm i have AMD quadcore 2.6ghz
4gb of i think 800mhz ram
and a 512 GTS250sc
i want to be able to keep a solid 60fps(min) in 25man raids with full graphics will i be able to do that with justa graphics card update?
Frost_Bite
and a 512 GTS250sc
Frost_Bite
With all the new updates, especially stuff like the water graphics updates, which isn't just water, it affects stealth and all sorts else, I would say to play on the highest settings, it would be your graphics card that is holding you back, because the rest of the system is fine for it.
However, you can't just go and update your graphics card, because it depends on the rest of your system. Because you have a GTS250, you obviously have a PCIe x16 slot, so that isn't a problem, but what power supply do you have? Manufacturer and model is needed, not just wattage
