p1pba52hz1.dll
ProtoKyuubi
Here's the message that comes up as soon as I load my user:
There was a problem starting
C:\Users\PROTOK~1\AppData\Local\Temp\p1pba52h1.dll
The specified module could not be found.
Any idea what this is about and where i can get a replacement? The message popping up whenever I start up is getting REALLY annoying and it doesn't seem to effect anything.
Looks like you have been infected. Please perform the following procedure.
  • then click Finish.
If you continue to experience problems after doing this, please post a HijackThis log by doing the following:
We will manually remove that error if this procedure doesn't do it.
thank you! I've been infected before so just tore apart the program in safe mode so since it stopped doing anything, i ignored it ^^
You still could be infected and not know it as many infections are hidden. So why not do the procedure so we can make sure you are clean? Plus we can get rid of your error on startup.
And it's fixed! Found some trojans and trackers. How do you know there was an infection?
Because I'm very good at what I do.
Please follow all instructions and post both malwarebytes log and hijackthis log. Even after doing this you still may be infected, but I can't tell unless I see the logs.
