I have ascertained that as a general rule I should match components to fsb speed. Now I am looking at this processor-Intel® Core™ i3-540 Processor
(4M Cache, 3.06 GHz), and from the spec I cannot find the fsb speed. Please advise. Also what is the good memory brands please?
ok im with you on that, but what about ram? The motherboard I am looking at supports ddr3 1066/1333/1600/2000. But which ram should I get? Actually does the CPU support all three ram speeds?
Socket 1156 doesn't have a southbridge. Socket 1366 uses Quick Path Interconnect, like AMD's Hyper Transport. But connects the southbridge to the northbridge on a DMI bus.
So Intel's Socket 1366 does have a south bridge chipset?
I just looked thru my notes and saw that Socket 1156 only has a north bridge chipset. All devices connect to the processor with Socket 1156 by Quick Path Interconnect or thru north bridge DMI.
"DMI" stands for "Direct Memory Interface" doesn't it?
Socket 1366 uses QPI to connect the processor to the memory, but uses DMI between the northbridge and southbridge. The PCIe lanes runs off the northbridge.
Socket 1156, the PCIe lanes run off the CPU. The CPU connects to (really what is left of the northbridge with the southbridge in one chip) Intel likes to call it the PCH (Platform Controller Hub) through the DMI bus.
