hi guys.. im new here.. i need your help.. my pc wont turn off..after i bought a new MotherBoard - ASUS - M4A88TD-M, a new memory ram cards - 2x 2gb DDR3 1333, and a new Processor - Athlon II X4 630.. the computer dont shut down.. i using Win 7 Ultimate x64.. i go on Start menu..and go set it to turn off.. but.. my pc just turn off the monitor.. the hard drives.. but the power suply stay with the coolers running.. and the GPU cooler is runing to.. it just turn off if i remove the power cable of the power suply..
Well.. i look at manual of the motherboard.. and all the cables are set right on the Painel of the motherboard.. but my computer WANT turn off..
Also.. if i press the Button to power of on the case.. the same thing happen.. it just turn off the monitor.. the hds.. but the Coolers of the fan and the power suply continues working..
another problem is.. when i put the power cable on the power suply.. it turn on.. i dont need to press any button on my Case.. it just turn on.. (it pissing me off ) i think it's the configs on bios.. but i dont know how to config it.. could someone please help me?
Thanks!
Thanks!
