Which moniters should i chose? from 2
phantom92tr1
hi all :)
I need a great and cheap screen and the choices i have got are
http://www.dpsy.com/product.php?prod_id=418&disp=
Which is a VH202T Asus
http://www.digitalnet-syria.com/Des...id/63/language/en-US/Default.aspx?Part_No=531
Which is a SyncMaster B2030 - DVI SAMSUNG
Those are what i can really afford, but there is this one which is much more expensive, but if its ALOT more preferable than the other 2, i can manage it
http://www.dpsy.com/product.php?prod_id=324&disp=]
Which is a Asus VH226H
Thanks alot :D
Edit: If ur going to chose the last one, pls only chose it if its significantly better, and chose one from the 2 first ones too :)
First of all, what are you going to do mostly on it? From the choices below i would go with the last one. I'm usually fan of Samsung though but that would be my choice.
